Took the time to replace the factory heat shield, as I was having some issues that felt like vapor lock. For instance, would go into Walmart, come out, and would have a rough idle for a few minutes until I drove around for a minute. I took pictures of everything so I wouldn't forget what I'd done, so here we go with a half-assed write up.
Step 1: disconnect the battery.
Step 2: remove your CCV hoses. I broke mine. Don't do that. Or, plan on it and get the parts beforehand. 47057, 47079, 42344 are the Dorman Motormite numbers. Then, remove your air intake hose.
Step 3: Disconnect your throttle/ cruise linkage. Should be able to use some needle nose and pinch the ends, and pull through the bracket. Remove the bracket as well.
Step 4: remove the clip between fuel line and fuel rail. Your fuel line is still attached via the locks inside the line.
Step 5: remove the fuel line. Place a rag under the line. It will have fuel come out. Mine was a 3/8 line disconnect.
Step 6: remove you injector plugs. The red clips will probably shatter.
Step 7: remove the 4 bolts on your fuel rail. The one by your IAC will be difficult to remove, so you may want to unbolt it first.
Step 8: remove the injector clips. They have a bit of pressure, so they may fly away. Be careful.
Step 9: remove your fuel rail. It'll take some effort. They fit tight. Just apply even pressure on both sides, or you may damage an injector or the rail. You will lose fuel. Place a rag underneath. Prepare for it to be soaked in fuel.
Bonus pic of my factory heat shield. It definitely seen better days.
Step 10: cover your rail. I removed mine and cleaned wirh brake cleaner beforehand. I also had to make a hole for the pressure regulator/sensor.
Step 11: install the manifold heat shield. It uses the head bolts. Middle lines up with the throttle body. Injector wiring cover holds it down.
Step 12: install new injector o rings. Or, replace if they're damaged. I just changed my o-rings.
Step 13: bolt everything back up. Don't forget the injector clips!
Step 14: should be done now! Just make sure everything is tight and mostly looking like it did before, aside from the shiny new cover.
