Current Atlas Wait Thread
Just put my order in today. July 7, 2021
ETA November .... Wow!
Update! It arrived today! WooWhoo!
Shifting an Atlas is simple. There are two things you need to remember. You can not have 2 high front only
Why is this? I thought the twin sticks allowed you to put each axle in low, neutral, or high. Is there an inherent bind when trying to use 2wd, front only? I would think that a front wheel drive Jeep would be great around town with icy, snowy conditions.
@mrblaine
@mrblaine
The Atlas has a lock out that won't let it shift into 2 high front only. That means it also determines how you shift in and out of high range 4wd. If you are in 4 high, you have to pull the front back first before you pull the rear back. It won't let the rear move until the front is in neutral and neutral matters because you can't have one axle in high and one axle in low.
If you are in 4 low going to 4 high, either goes to neutral first, then the other one, when both are in neutral, then the rear axle has to shift to high first before the front does because again, you can't have 2 high front only.
If you don't want to shift hands back and forth on the shifters going from low to hi, then shift the front to neutral then the rear can go from low through neutral to high.
Thank you for explaining that, though it bums me out a bit. I was looking forward to an option of a front wheel drive Jeep.
On another twist...I have an 8.8 rear end. I know that affects the rear driveshaft length and I am assuming a 4 speed would make the rear too short. Has anyone put this combination into play?
I am leaning heavily towards the 2 speed but still have not decided between 4.3 and 5.0.
Cutting brakes are also called steering brakes like on a tractor. Lock up the inner rear wheel to make it turn sharper. Works even better with front digs.
You have to have a selectable rear locker for that application but it is the shit, I have a spool in my rear diff so I just drag my entire rear axle but in certain situations it works very well. If I ever have to go into my rear diff I would love to install an OX manual setup.
Reactions: B00mb00m
It becomes second nature after you use it some, I was fortunate enough to get some insight from a friend on how to shift the Atlas.
Reactions: mrblaine
I measured the Atlas 2-speed against my 241 (not sure if 231 has similar lengths.
So I got the 3.8 2 speed I bought used installed, and I am installing twin stick. Does anyone know how long to cut the dom tube? I called advanced and the basically said just stat cutting till it works? WTH? It’s not like this hasn’t been done before…
Not all Jeeps are the same so I can understand their answer. Start with the rear in high and scroll to my post, post #198. It has a good explanation on how to setup the levers. I considered the lever installation the easiest part. Good luck!
Reactions: Wildman
They used to cut them and now they don't. You mock up the shifters, if they hit the front of the console slot or dash, shorten the tube. It is about the suckiest part of the install.
Oh my dom tube was 2-3/8” and I used loctite 648 retaining compound and punch marks on the end of the tube to keep it from rotating.
