Crank no start
Fat Jazzy Jeep
Hi i am in need of some help,
I have a 97 tj 2.5 5 speed it will crank but not start. it was throwing codes p0320. i have replaced the following parts: coil, crankshaft sensor, cam shaft sensor, emc, plugs and wires, rotor cap and bug, map sensor, relays, fuses, fuel regulator, electric ignition, battery, starter.
it went down while i was driving it spit and sputtered then just died. i have go it to start 3 times since then but only to get it out driving and it did the same thing all three times. i have been fighting this since Feb. can someone please point me in the right direction to how to fix this. all the ground wires are good i have checked them. thank u for an advise.
I would definitely check the wiring on both ends of the cam sensor & crank sensor. Had a friends jeep was running fine, then all of a sudden crank no start.
turned out the insulation on the cam sensor had pulled back in its old age and some wires were touching. It's pretty easy to check, I would absolutely look at that next. That p0320 could be either crank or cam related, so check both.
Also many here will tell you to only use Mopar sensors....I have had fantastic luck with non-Mopar parts but I can't discount what others have experienced.
Reactions: Blondie70
thank u i will go check them right now
