Hi i am in need of some help,
I have a 97 tj 2.5 5 speed it will crank but not start. it was throwing codes p0320. i have replaced the following parts: coil, crankshaft sensor, cam shaft sensor, emc, plugs and wires, rotor cap and bug, map sensor, relays, fuses, fuel regulator, electric ignition, battery, starter.
it went down while i was driving it spit and sputtered then just died. i have go it to start 3 times since then but only to get it out driving and it did the same thing all three times. i have been fighting this since Feb. can someone please point me in the right direction to how to fix this. all the ground wires are good i have checked them. thank u for an advise.
