New to me 2005 TJ Rubicon. Have done a few maintenance repairs. Had the death wobble tonight..... looking for local Citrus County shop who will go through the suspension...
Here's how to check and adjust your own toe-in that also includes how to center the steering wheel as well as re-center the axle if necessary. With just a little care on your part with nothing more than a tape measure, a big set of pliers, and a wrench, you can easily set your toe-in with as much accuracy as an alignment shop can. Really.
Start after making sure the front axle is properly centered. That may involve adjusting the trackbar's length which can only be done if there's an aftermarket adjustable-length track bar installed. Or if the original OEM track bar is still installed and...
