Center High Mount Stop Light Cable
wkelley70
Eagle, ID
Does anyone know where I can get the connecters and grommet for the Center High Mount Stop Light cable. I need to extend my cable and do not want to cut up the stock cable.
I’ve looked for those connectors and similar grommets and never found anything before. Anytime I’ve needed to do any work I either sacrifice what I have and make it longer or buy a spare lamp/harness off eBay and hack that one up instead.
Reactions: wkelley70
Why don't you want to cut and splice a length of wire in? That's how it's done.
I hate to do anything to my Jeep that prevents it from being returned to original. If worse comes to worse I will have to do a splice though.
It's 20 years old. A lot of original parts are no longer available.
Get some heat shrink butt connectors, a crimper, and some 16 awg wire from amazon and get the job done.
Here's the crimper I use:
https://www.amazon.com/dp/B00Y7M7SG6?tag=wranglerorg-20
Butt connectors:
https://www.amazon.com/Waterproof-E...-Decoration/dp/B0BNXRSMB5/?tag=wranglerorg-20
16 awg wire:
https://www.amazon.com/Ancor-Marine-Primary-Battery-Yellow/dp/B000NUXCB6/?tag=wranglerorg-20
Butt connectors:
16 awg wire:
You have changed my mind on this. Exposed wiring is kind of a disposable item anyway. I will do the splice. It is not the same as cutting up an OEM fender.
