Can’t get Detroit Axle tie rod ends to take grease
bhellis33
Denver, CO
Hey, all. Replaced my drag link and tie rod ends with Detroit Axle stuff. For the life of me I can’t get these things to take grease. Any thoughts? Thanks!
Pull the grease fittings and see if you can push grease through them.
If you can then it's the internal passages and you might need a grease buster or a drill.
-Mac
Reactions: CharlesHS
Don't be ashamed of buying Detroit Axle. They work. Maybe not top of the line but who cares? It's your Jeep. Put as much or as little into it as you wish.
Good chance they have cheap grease zerks. New, better ones might be all you need.
Thanks for the advice. I replaced the zerks (and used a different grease gun) and it worked. Re Detroit Axle, you are absolutely right. I know people like to share their opinions so I was trying to cut it off at the pass.
south park mob GIF
