cam tabs on from LCA axle mount purpose?
Cumsterdump
Arizona
i just put in new control arms and when doing the fronts i noticed the lower control arms had adjustments on the axle for some alignment purpose but when i pulled them the cam washer wasn’t offset like ive come to know from other cars. i found no way to adjust anything and am more so curious what im missing. thanks:)
You are missing eccentric washers.
If either your upper or lower control arms are adjustable, this is what I did.
I tack welded them in as well.
