Blinker issue/not working when lights are on
michaellaf
Vancouver, BC
Hi! So, I just installed a new LED tail light on the right side (the left tail light is not installed and there are only exposed wires). Everything works fine, but as soon as I turn on the lights on my 1998 Jeep TJ, the tail light keeps working but the blinkers don't work anymore on the right side front and back, and on the left side front.
I've read that it might be an issue with not having front LED blinkers, so I changed the two front blinkers for an LED set, but now, blinkers still don't work when I turn on the lights AND when lights are off and I use the blinker, hazards turn on and the dash flashes as well. Super confusing!
Additional info: I've just changed the flashing relay for one that works with LED's, and has 5 pins instead of 4 like the old one had.
Thanks for your help!
Sorry I couldn't help myself
Maybe share what LED lights you bought. Someone may have experience with whatever brand you have.
Are the new LED lights grounded properly?
Is the flasher suitable for LED use?
It’s an Amazon product, brand is SUPAREE. Flasher is suitable for LED’s, I bought one off Amazon as well. Only difference, though, is that the LED one as 5 pins, and my original flasher relay had 4 pins.
