AirborneTexasRanger
988 Suicide & Crisis Lifeline, Help is available.
Lifetime Supporting Member
I’m using a 10x Lupe and proper lighting to inspect - but would like to etch it - are field kits ( aka cheap) inspection / etch kits available?
You can use any of these: hydrochloric acid, ammonium persulfate, nitric acid, or iodine, and potassium iodide
1. Sand the cross-section of the weld to a uniform 600-grit finish (I use 220 grit sandpaper), before etching. Mirror polish the surface if possible. The finer the finish, the more details you will see.
2. Apply this chemical with cotton swabs. Allow it to stand for a few seconds to minutes.
3. Once the weld is visible, rinse it with water to stop the reaction.
