Airbag Light Stays On
TJRick
South Carolina
I have a 1998 model with the 4.0, and the AIRBAG light came today while I was driving. I turned it off a couple of times since, and it is still on.
I haven't done *anything* to my Jeep in at least 6 months.
Everything else seems to be working fine, including the horn.
I checked the two fuses behind the glove box, and they both look good (not broken).
I do not have a passenger side airbag defeat switch in my center console.
Does anyone have any ideas?
You need a scan tool with SRS features so you can pull the SRS specific codes it's throwing. That should point to your issue.
Reactions: Danarch
If you would answer your phone you could have already been covered by car shield and not have to worry about such trivial garbage.
