I hope tomorrow goes well.
Just remove the control arms while you're there!!
My head is spinning! So what happens if he does the front end, and it sits another month while he procrastinates on the rear? Now he'll have you by the nuts.
Hope it works out in your favor. I'd go literally nuts if I was without my jeep for more than a month. BAT SHIT CRAZY NUTS!!!!
Indecision certainly seems fitting now. Hopefully tomorrow goes well, but if not, at least you've already got your Savvy lift ready to go!
What gets me is what if he “starts” on it but doesn’t have much done. Then you can’t even drive it home. I would just tell him to leave it alone and pick it up and go. Just install the kit you just bought.We will see. Dave reached out to me personally after I told him I was taking my Jeep back this Saturday. He insisted he was planning to start on and finish the front end this weekend, so when I go up there on Saturday with Sri, we will see. If it’s not being worked on, I’m just going to take it and go somewhere else for the Savvy install.
A good majority of those Jeeps have been sitting in that lot for 6 months to 1 year. I’m not going to have mine sitting outside for that long haha.
I honestly don't see how the Savvy kit can be that bad compared to his. Everyone I have talked to with the Savvy mid-arm has nothing but praise for it. Jerry, jjvw, John Beard, and a number of others.
I found good images of the JW kit on FB. It's a different approach than Savvy. JW keeps all of the axle mounts but eliminates the front tube side tower to create the front 3 link. Whereas Savvy only keeps the lower axle mounts. All of the uppers are moved and raised with a bridge over the diffs. The empty front tube side is reenforced with a brace. The Savvy rear uppers are triangulated and eliminate the need for a track bar.
The frame side mounts are probably more different than they might appear. Savvy looks to have more vertical separation than JW, but JW's upper frame sides are adjustable. Then there is the JW rear track bar.
The geometries are different. I can't and won't say which is better or worse, except that I am pretty sure I see where both are better then stock after a 4" lift. As has been noted several times, the presence of a rear track bar, along with the front, will have an advantage in minimizing body roll.
These are the the similarities and differences I see.
Amen! It’s the principal of the matter. Your jeep has been sitting literally sitting...getting a nice rain bath everyday haha pull it out lol@Chris, I've been sandbagged before...it involved a BMW motorcycle radio but thats another story.
Do you think that JW just "happened" to be starting work on your Jeep this weekend? Or is it possible that since you have a large voice in the TJ community and started rattling about pulling the project he figured he better jump on it?
I'm guessing he'll tear into it and get it half done to appease you and you'll still wait another month or more to get it back.
Kudos to you for giving them the benefit of the doubt. I'd show up there Saturday and pull the jeep out so quick his head would spin. But I'm a dick when it comes to things like this.
Savvy was born out of Johnson Valley and KOH, meaning it is designed around both aggressive rock crawling as well as speed. I wonder what the personality of the JW setup is reflective of.
looks like he's doing some work on @psrivats from fb pictures!
Yea man he literally burned you on this one. I would call him and demand he not touch it just so you can cut your losses at this point and get a coat of wax on it haha. If it were kept inside it would be different, but it’s not.I had mentioned that to him as well. I said, "Dave, you know how easily things things rust out... why would I just want it sitting outside in the rain for months on end?".
I like the fact that it's rust free... I'd like to keep it that way.
Yeah, yeah, it's just rain, I know. But still, we're not talking about a day or two here... we're talking about a month straight, and probably even longer!
Like you said, it's the principal of the matter.
