Hello! First post here, but belong to other car forums. GOTTA say this place seems really great! Lots of good help I am reading and really smart folks, passionate about jeeps!
I have in my garage, on my scissor lift a 1997 2.5 Jeep wrangler. About 174k on the clock. This vehicle sat for at least a year, according to the owner, (I think more like three or more) before she retrieved it and brought it to her current house. I towed it to my garage a week ago and have been pecking away at it.
She said they put 'cleaner' in the gas, then some fresh!?!?!?! It will start, sorta.... will not idle, or drive stalls out very quickly.
I found one code:
A P0463 indicates a "Fuel Level Sensor Circuit High Input," meaning there's an issue with the fuel level sensor or its wiring. This can lead to a variety of symptoms, including an inaccurate or fluctuating fuel gauge, or a stuck gauge. Possible causes include a faulty fuel level sensor, a short in the wiring, or a problem with the fuel sending unit.
Did not think this was the problem with the motor, am I wrong? I do notice sometimes the fuel gauge says about half other times it says empty....
What I have done:
Replaced the crankshaft sensor.... one off amazon for about 20 bucks... Result, no change.
Pulled, cleaned and replaced the distributor, rotor, button etc.... result, no change...
Pulled and cleaned the throttle body, found a bad o-ring on the IAC, it was probably the wrong one and someone just tightened it down. One quarter of it was all smashed flat.... might have still been sealing but not sure.... Result, no change....
After all the attempts at starting the engine... I think the starter is going out.... Battery is fully charged, but sometimes it will not crank... dash goes blank... Nada, nothing, goose egg....
I remove the cables and put then together to (I guess it clear out the CPU, read that here) and i will bang on the starter a bit.... turn the key, lights again... cranks but nothing different...
If I uses some either, aka starting fluid, it starts right up but runs like crap... and dies does not help that the exhaust dounut is bad.... sorta loud lol but it makes it hard to see if its missing or not..
I looked around at the wiring et al, and have not noticed any issues... yet... fuese box is flopping loose.... but no bad fueses or wires I have found yet.
I am starting to think its a fuel issue (DOH! I mean it should not take a genius to come up with that after all the time sitting right... lol...) but not sure how to proceeded there.... I dont have a fuel pressure tester, I may need to get one.... So suggestions there might help me....
I have done lots of car work, r&r motors, trans, etc... so I can do the work.. This Jeep is providing me some challenges sadly... I have read a lot of posts here and they have been very informative.... Seems these issues are a common problem with jeeps of this era?
So do I try to drain the tank? Take it down? test fuel pressure first?
Thoughts anyone, and thanks for reading....
Schaeff58
I found one code:
What I have done:
Schaeff58
