Laws8665 New Member Original poster Joined Jan 10, 2023 Messages 7 Location McKinney, Texas Jan 2, 2025 #21 If it does engage, are you sure that there is enough overlap to handle torque loads, or are my concerns unwarranted? Thank you!
mrblaine Crew Member Supporting Member Joined Nov 20, 2015 Messages 32,426 Location Quail Valley, CA Jan 2, 2025 #22 Laws8665 said: If it does engage, are you sure that there is enough overlap to handle torque loads, or are my concerns unwarranted? Thank you! Click to expand... You'd be the first if it didn't. Reactions: machoheadgames
M machoheadgames LED turn signal club Supporting Member Joined Jan 21, 2021 Messages 2,637 Location Dallas, TX Jan 2, 2025 #23 Laws8665 said: If it does engage, are you sure that there is enough overlap to handle torque loads, or are my concerns unwarranted? Thank you! Click to expand... If it was a problem, the factory wouldn't have used the short input on the AX15 all those years prior to 1998, before they started using the long version. You'll be fine, you'll break plenty else long before that is ever a consideration.
Laws8665 New Member Original poster Joined Jan 10, 2023 Messages 7 Location McKinney, Texas Jan 3, 2025 #24 It's installed and working fine. Thanks again!
