HELP!!! I have a compressor that stops blowing cold air early. It also won't turn off completely as every position on the dash won't turn off the compressor. This jeep has been in a very good shop but they can't figure out the problem either. The pressure switches have been replaced, compressor replaced, tube verified not clogged, new computer, no leaks found, and refrigerant level verified. They have hooked up a light to help determine when the compressor was on and off and that is when we discovered there is power in every position on the dash except off. Wire diagram obtained online does not make sense as we were looking at bypassing the current wiring in thinking there might be a short somewhere. Any help would be greatly appreciated.
