For anyone else following along, your focus on tire clearance is less important than frame clearance. The tire rubbing on the springs is annoying, the body of the shock/dual rate cup binding against the frame can bend the shock shaft, take out the seals and is far more critical than some missing paint on a spring.Something got out of whack somewhere, my driver bracket ended up higher than my passenger bracket. I need to recheck axle position tomorrow. As it sits everything clears tho which is good.
View attachment 618737View attachment 618738
With that disance from the shock body, I'd at least try to swap the caliper to the back side of the axle, articulate it, and see if the shock body clears the caliper at full articulation.
