I will, ordering ring pinion next month. I saw
I recall seeing fab-tech literature stated its painted black, all blue kit is for advertising purposes. My front springs are blue with fabtech markings.
View attachment 602277View attachment 602278
Degreased parts with ZEP, warm water and brass brush, followed with pressure wash. A-arm bushings did not have grease fittings installed. I have not closely checked the condition of bushings yet, they appear ok.
Not sure how springs come fab-tech, appear to have been powder painted red already, more shall be revealed. I will paint a-arm and long arm members with VHT satin black roll-bar/chassis paint. Springs? I have read a bunch of threads on what paint to use for coil springs, opinions varied.
I just have not mustered the energy to pull t-case yet. I am not at peace with the DANA 35 as is. I am leaning towards ordering new ring/ pinion set and pinion install kit, Order new seal housing and inner seals for ARB to be functional again. The axle is out, I can lift it up on horses (the one benefit of Dana 35 is not that heavy) and do it myself again, be a lot easier than sitting on jack stands as I tried before. I decided to keep Dana 35, no future rear axle upgrade.
View attachment 602813View attachment 602816
New UNI-Ball installed, good thing the old snap ring was reusable. Replacement comes with snap ring for F150 lift kit, uses same 5ton uni-ball.
Got the a-arm and long arms painted, no pics yet.
Got a hold of Quadratek today and we feel they are Eibach springs, they sell red custom barrel springs. Put a call into them, waiting for return call.
I think I am going to add these to my list, before RP set?
Dual rate 6” lift, I think these springs will be good for my intensions to do overland type wheeling with overland trailer.
I will talk to Eibach first to verify what I have and what options are available. I would prefer to go with them. They may manufacture the springs for skyjacker.
If you're going to tow a trailer you might want to look at installing some air bags in the coil springs to help with the tongue weight of the trailer and to keep it from sagging in the rear.
https://www.airliftcompany.com/shop/60811
There you again, make me spend more money. That’s ok, I like the air bag idea.
Good ol’ fabtech, trying to source new bushings, shock bushing mount id Is 25mm or 15/16”! I Can’t find such an animal….yet. Found 1-1/16” id, shave down somehow? I may just pick up the skyjacker Resi long travels instead. That will blow my May get er’ done target date.
Well, I ran her around today on local streets and the on the freeway for the first time, With all driveshaft/gear/suspension noise gone I can here the issue with t-case whole lot better more so in today’s 90 degree heat.
So new plan have a little fun with it this weekend and put it back in the garage for more work. Remove t-case for rebuild and rework front end as I did the rear. After freeway ride at 55-60, front end rework, I feel, is required.
Putting any 4x4 action off until end of summer? Wife really starting to like it, she wants to go to Pismo Beach in it. I’m all for it, shooting for September.![]()
COOL..... I'll bet you had a blast too.
As you fix one thing it never fails the next thing seems to crop up. I'm curious to see what you find out is wrong with the t-case.
Back in the late 60's my grandfather used to take me to Pismo in his CJ5. Specialty tires weren't a thing yet so he'd get bald tires and haul them down in the trailer I now have. We'd swap them out in the parking lot and run the dunes in the bald tires. I can say I'm sure he's a BIG reason I like Jeeps as much as I do.
And he wasn't scared to get some air in that CJ5 either.
