Hey guys,
Hoping someone can help me diagnose my issue. I've been reading many threads but couldn't find the same conditions mine is experiencing. Picked up my daughter from softball last night, and about 5 minutes after I turned the Jeep off, I went back in to start it. Nothing happening- gauge clusters operate as usual, but turning the key did zilch. I cleaned and re-tightened both battery terminals, tried jumpstarting just to see and nothing. Checked starter fuses and swapped relay with the horn relay (which worked when honked horn) and nothing. I assumed the starter had gone bad and tapped it a few times and nothing. Tried jumping the starter relay, and the starter did engage, fan spun etc. but the engine would not turn over- it just kept cranking with zero sign of catching. Called mechanic and he thinks it could be that the starter is turning but not fully engaging, but I need to tow the Jeep over to get it diagnosed. In the meantime I figured I'd see if anyone else might have a suggestion.
I did not check to see if the ignition actuator pin was broken or replace the ignition switch since I don't have spares, but wouldn't jumping the relay bypass those?
Thanks ahead of time guys! Appreciate any help
