04 Rubicon Opinions
  • Thread starter Thread starter NOVA-Jeep
  • Start date Start date
N
NOVA-Jeep
Guest
Hello All,
Another TJ question. I think I've found my unicorn: it's a 2004 manual Rubicon with 164,000 miles and a hard top. The owner is retired naval aviator who I believe when he says there the jeep is in as good condition a condition as it looks. The muffler is rusting (no pics) and there is some surface rust on the drivers side tub under the carpet. Overall the Jeep looks awesome and drives just like a TJ should.
The only minor issue when we got back from the test drive and parked on his driveway (very minor slope, I'd call it almost flat), I put on the parking brake (I thought I pulled it up enough, but in retrospect not sure) and l took the car out of gear and turned it off. The jeep started to roll backwards. No drama, I got in and pushed the brake and put it in gear. No problem after that, but is that something I need to be concerned about?
Owner supplied frame pics — the main reason I'm buying it unless someone has a strong reason not to.
Thanks.
Buy it ASAP if the price is right for you. Jeep parking brakes suck and usually need adjusting. That is normal and takes 5 minutes to fix yourself.
p.s. I bought my one owner 03' Rubicon from a retired Air
force guy. He kept every single record from the day he bought it, window sticker too.
That frame was painted and looks rust free, Give me the ad or phone # so I can buy it before you. I just noticed you're in VA like me.
Sorry — we already agreed, mostly based on the fact I trust the guy I'm buying from. But like all ex-military, you always verify!
Looks good from the exterior
Just noticed it does not include the wider Rubicon fender flares. Looks like someone opted to paint match the fender flares using the normal TJ ones.
