Taking care of some rust on my frame. Here's the deal and some questions...
Dropped the shield and where it attaches as well as some other spots there is some surface rust. Nothing where I have lost structure yet, maybe half a millimeter in the worst spot. Also in a couple of spots (not most) I stuck my fingers inside of the frame and there was a little bit of flake and grit vs smooth painted metal feeling on most spots.
Couple of questions.
1. Exterior I am using a wire brush wheel on a drill. This has removed any minor flaking. There are still areas rust colored. I plan to coat with rustoleum rust reformer and then paint. Is this likely to work long term? Alternately is it critical to get it down to shiny bare metal before coating?
2. Inside, best I can think to do is plug all but 2 holes then use my compressor to blow out whatever I can. Then I have some eastman interior frame coating. It is one that comes with the tube for inserting into the frame and a I assume a 360 degree nozzle. Any experience with this? if I want to do both rils how much am I likely to need?
Thanks!
Thanks!
