Engine Oil Recommendation
WLDRIDE
WLDRIDE
SouthCentral Colorado
What brand, variety, and weight of engine oil do you recommend for the 4.0? Additional info: 240K miles, and cylinder 5 is burning oil. Thanks!
10w30/40, standard dino oil for me
Rachael Harris Popcorn GIF by Lucifer
I like Valvoline products, so that's what I recommend, but honestly most modern oils are good so pick whatever brand name and flavor you like, and stay with it. Synthetic has better temp range/stability. Weight is 5-30 or 10-30 normally, but if you're burning oil, you could bump that to a 10-40 and see if it helps. The question is why are you burning oil, and how much?
If you are burning/leaking oil, a high mileage oil can sometimes help. Valvoline Maxlife synblend 5w30 helped significantly reduce a rear main seal leak on several 4.0 engines I have owned/serviced over the years. I usually use that oil in the 5w30/10w30 flavor. Since you have higher mileage a 10w40 might help slow oil consumption. These engines are not picky with oil.
Thank you, I will keep it in mind.
10w30 Valvoline VR1 or 10w30 Rotella T6 and a Wix 51515 Filter every 3k Miles and no more for me
The zinc rich content of the oil helps some since were all rockin flat tappet engine......unless your a cool guy with a newcomer racing hyd. roller cam 🤙🏼 But yeah I need everybit of protection to make myself feel better lol 😆 My LJ lives at rev limiter so the added protection that these oils provide make me confident to send it hard and i have been for the past 70k miles in the last 2-3 years of ownership with my jeep :D
Edit- My LJ is at 258k miles
