Wrangler TJ EV Conversion
Please, I've tried everything to figure out how to maintain the drivetrain in an automatic transmission set up.
The state of art right now is a TorqueTrends 1.9:1 reduction unit that sits between the Dana Motor and the NP231 TC.
The Austrians make a similar version that's being used for F-150 conversions. They were pushing me to try it but I thought I'd still with the US made TorqueTrends for now.
My wishlist would be a 2-speed planetary gear reduction unit.
Jeep applied for a patent for this but unfortunately, so did GM and about a half dozen other auto makeres or OEM auto parts makers. Nobody has one or have shown one, yet.
It's early days in this, our new found world of electrified moving parts.
Exciting times.
- Patrick
Does anyone use a powerglide transmission? 2 speed planetary, known for being super strong with tons of aftermarket support.
It's a legendary transmission, to be sure but, once again, it's still a hydrostatic component, albeit a geared flavor. The thing that keeps it going is to have some form of hydraulic pressure and that's not a thing in the EV world.
If you start from the ICE propositions that the motor is always running to used, everything after that incorporates that into the calculus.
BUT, if I was a smart engineer, I'd sure as shit use it as a guide for what could be a 2-speed solution - super interesting idea @srimes!
- Patrick
Reactions: speeding_infraction
I'm working on this part of the Tech Box:
I need to get the Power IN to the Tech Box to branch off to +B and -B on the Inverter.
If you scroll back up, I put a diagram showing the layout.
Here's the parts that make up most of that, graphic view to see what I'm working on:
- Patrick
Exciting times.
- Patrick
Just to float this in case it hasn’t been considered, Advanced adapters makes a 1:1+2 speed under drive unit called the rubicrawler for the 42RLE/231
Yes, that is also interesting but, I think less OEMy - you have to basically stop to shift, if I read this correctly.
BUT, absolutely worth the effort to call Advanced Adapters when this build is done.
Very interesting.
Maybe, I wonder if you'd have to stop to shift if we did the same thing we do with manual transmissions and program in a 'motor' rpm to follow a similar path to idle speed.
Yep, gotta' give them a call later.
Thanks for that,
Patrick
Alright, so where I am in this build is here, working on the Tech Box, here it is.
If you go back a couple pages, I put a basic diagram of the Interconnects (this usually refers to moving power, DC mostly, from point A to point B.).
This box will have the bulk of the LV (Low Voltage) wiring in it also. Things missing on the outside are the LV master Sw., about 6 flanged connectors to deal with Jeep stock PDC (Power Distribution Unit) wiring, maybe a fan to keep airflow in the Tech Box. Also, have to hook up the HV 'small' stuff - A/C, OBC-DC/DC Charger, internal Precharge.
The Tech Box, our first in this size/format, always takes a bit of time. All together, about 9,000 wires and connectors (slight exaggeration...).
I'll try to post updates with a bit more frequency.
- Patrick
Progress, obviously...
(you might need to squint, but progress is there, somewhere, probably under that thing on the left...)
Working on wiring. You get all these harnesses and you have to make connector decisions based on where the source of the wire is and where the final destination of the intent of that wire is.
You end up cutting and assembling connectors based on what will hook up inside the Tech Box, what's outside, where's the components pig-tail (we add pig-tails for the LV stuff for ease of installation / repair). Takes forever the first time. Constant second guessing and trying to imagine what will go around it and will it see exposure to the elements, does it need additional split loom, how to make a bracket to hold the connector, etc., etc., etc.
I really like this part but, it's a lot of crap floating that has to eventually solidify into a nicely bound and secured harness.
Stuff.
- Patrick
Okeydokey, here we go, mo' progress.
I'll try to go in some sorta' order but, you know, stuff...
Also, try to remember, everything we do here, has to have a production run purpose to it. What does that mean? Nothing can be one-off. Everything has to easily and technically be repeatable and not just by me or a trained EV installer. No, can't do that - all things have to have a modularity an average Jeep mechanic with a decent tool box and a cherry picker can install.
If you can install a motor and get it to turn over, then you should be able to install one of the eventual retail kits into your own Jeep, with the help of Jim, you're neighbor, the one with all the new tools and the kinda' flirty wife, that guy.
So keeping that in mind, we don't build one-offs and we don't get caught in garages alone with Jim's wife, as if I had to say that out loud.
Onward...
Moving the wiring harness from the wiring bench (see last post) to the Tech Box means that I've finished breaking down some of the wiring harnesses. Here's what that looks like this ridiculous 86deg Nov 9 winter day in Los Angeles - who loves global warming - ME!!!
I've also finished the reconfiguration of the stock engine bay Jeep wiring harness and the PDC (Power Distribution Center). Mostly removing (depining, never cutting) the things like O2 sensors, starter relays, various sensors (engine temp, MAP, TPS, etc.). I'm not in love with this bussed fuse block but it works for now. The alternative is 100% custom and I'm out of time for that nonsense, at least for now.
One of the big things is making sure the stock Jeep functions work, you know, brakes lights, IGN key stuff, radio, blower, all that things that have to keep working despite the open-heart surgery. Here's a quick video:
Here's where the Tech Box is going to fit.
Have I mentioned that all EV conversion comes down to bracketing, never ending bracketing.... Here's a mockup of the brackets that will carry the HV Cables, 3 coolant hoses and the J1772 (charge port) harness from the back of the Jeep to the front where are the action is. One of the hardest things about making brackets is figuring out how it will actually assemble and fit in the Jeep. Many a brilliant design goes down in flames when you figure out that you've made it impossible to screw something to something around something connected to something that you didn't think about till now....why do bad thing happen to good people?!?
This design works, at least in cardboard and blue tape. I'll follow up when I make it out of AL (for all you crackers out there, 'AL' means aluminium AND Alabama, who would have thunk it!).
I know there's a ton of questions and I equely know I could be more informative, like the Jeremys (Jeremy Makes Things (link:
and Jeremy at Electric Supercar, link: https://www.youtube.com/@electricsupercar ) - I don't know how they do it, I can't even be bothered with editing, sorry.
Back to it!
-Patrick
