TJ 2005 I was sat in traffic and noticed and regular "solenoid click" followed by a light whining for about 5 seconds then off. Then the same again. Repeating.
No other issues with car at all.
video is too big for upload. Let me know if it would help me to email you video.
Was your A/C on? Sounds like the same behavior as the compressor cycling on and off.
To post a video you need to load it onto something like YouTube.
Sounds like the compressor kicking on.
Was the A/C or defrost on?
If it's the compressor, you should see the compressor clutch engage and disengage in synch with the sound.
AC was not on but I will check that
I don't know what the compressor looks like but I'll search it.
Wow, a TJ in England! Thats fab!!!! I used to love English cars, still have one, made long ago in Coventry. TJ is just like 60s English cars even leaks oil![]()
It is on the left side under the power steering pump. The center part will only spin when it's clutch engages. It cycles depending on ac system pressure. Start the jeep,look at it and you'll see what I mean
Great I'll have a look. Interestingly when I checked the pressure on the AC on a little guage I have it says it's poss too high. Honestly I don't know a huge amount about AC.
