Nose identification: solenoid click and then slight whine
Roger Dunning
Chichester, West Sussex, UK
TJ 2005 I was sat in traffic and noticed and regular "solenoid click" followed by a light whining for about 5 seconds then off. Then the same again. Repeating.
No other issues with car at all.
Video -
  • Face Palm
Reactions: Zorba
video is too big for upload. Let me know if it would help me to email you video.
To post a video you need to load it onto something like YouTube.
Reactions: macleanflood
As far as your noise? Could be something to do with the emissions system? Since it's a Export model I'm not sure if there is anything else that might be different.
Sounds like the compressor kicking on.
Was the A/C or defrost on?
If it's the compressor, you should see the compressor clutch engage and disengage in synch with the sound.
Reactions: Rickyd
Nah. Ignore it. There's no sound insulation in these things, everything is loud. If the AC ever goes out, deal with it then.
AC was not on but I will check that
I don't know what the compressor looks like but I'll search it.
It is on the left side under the power steering pump. The center part will only spin when it's clutch engages. It cycles depending on ac system pressure. Start the jeep,look at it and you'll see what I mean
Wow, a TJ in England! Thats fab!!!! I used to love English cars, still have one, made long ago in Coventry. TJ is just like 60s English cars even leaks oil :ROFLMAO:
Reactions: Roger Dunning
Did the nose look like this ??
Great I'll have a look. Interestingly when I checked the pressure on the AC on a little guage I have it says it's poss too high. Honestly I don't know a huge amount about AC.
The compressor cycles under normal operation. There is a high pressure switch on the high side and a low pressure switch on the low side. If pressure gets too high, it shuts off until it drops below the threshold. If it's too low on the low side, it shuts off to prevent starving the compressor. The low pressure switch is the one that saves the compressor if you have a leak and lose too much refrigerant.
The whole system is described in detail in the FSM that you can access on this site.
It's supposed to cycle on and off, depending on ambient temperature and engine speed. Do English cars still not have A/C? Well I guess there aren't many English cars any more. Morgan maybe. Sigh...
