I feel your pain. I have disc brakes that have pads and calipers, not shoes.
How does your parking brake work ? Ours use the shoes for the parking brake .
Slab City maybeUntil Cali lets them loose again. I wonder if they get sanctuary city status.![]()
Good luck with that. Mine lasted six months and died. Called Warn. They didn't have any replacements. Said call back later. I did. Then they said my one year warranty was up and sorry.
I bought a $13 remote from Amazon and wired it in and it's so much more reliable.
Which one from Amazon do you have? I've been looking at a couple for my Rough Country winch but haven't decided on one yet.Good luck with that. Mine lasted six months and died. Called Warn. They didn't have any replacements. Said call back later. I did. Then they said my one year warranty was up and sorry.
You shouldn't need to freeze anything - just heat the bearings up. I've used a hot plate with a small sheet of steel on top (to better distribute the energy) for decades when building motorcycle engines, and I did it with my Dana 44 axles a couple years ago. Just don't heat up sealed bearings.Going the freeze and bake method. Pinion in freezer now, warned wife about baking bearings and ring gear in toaster oven tomorrow. I am going with shim set up that came out with fresh bearings. My gut feel it will be good. Races pressed in, inner with .004 shim. I don’t want to put the locker in the freezer, Bag of ice in journal maybe. Rear brakes on hold for now. Got to er on the road before Xmas !
The hot plate works a lot faster because you're relying on conduction, rather than convection. Hot plates are cheap, and you can keep it in the shop so you don't need your wife's permission. Here's a name-brand hot plate and a no-name hot plate, for example:
https://www.amazon.com/Proctor-Silex-Adjustable-Temperature-34106/dp/B086BYH8LJ/?tag=wranglerorg-20
https://www.amazon.com/OVENTE-Count...ure-BGC101B/dp/B07HGG378Q/?tag=wranglerorg-20
My 04' LJ rear brakes looked much different than his pic he posted. You got screwed too?
Replaced rear brake pads and calipers.
Decided against new backing plate for now…
Did you have to pull the axles?I did mine without and will never do it again.
In the last few weeks:
1. Replaced Starter.
2. Replaced Fuel Pressure Regulator. It died on me while driving and had to have it towed home. $50.00 later from RockAuto and it is running great now. Even a bit peppier (if there IS such a thing with a 2.5L engine LOL). May just be a placebo, but it does great.
3. Adjusted castor on the front for better steering feel.
4. Installed new Replace-A-Top after 20 years running the previous top. Upper door skins are a PITA and we haven't been warm and sunny enough to put them out in the sun to stretch and work over the frame more easily. Any tips to finish that off would be nice.
5. Installing new amp for the front/rear speakers. Old Kicker amp from 2004 finally died after water/dirt messed it up. Went with a simple Jensen 4ch amp from WalMart and will be installing it up off the floor a bit just to help avoid water a bit better if it gets in.
6. Washed it. It is now sitting in the garage with new top on, but no upper door skins currently (see #4 above LOL). So it is still clean!
After neglecting it in the driveway for several years, lots of little things to do to make it ready for the road.
