So, I'd like to use the Midland – MXTA12 MicroMobile Antenna Mag Mount
and route it through the hole from the 3rd brake light
I am assuming my only option is to cut off the connector and splice on a new one... probably shortening the cable, and taking out the excess length. Is there an easy solution to put a new end on the cable? Many years ago, I spliced cable tv coax cable - guessing this is more or less the same thing?
If there is a better solution, let me know... I'd rather not make this more challenging than is needed.
