It's too bad you weren't able to get the 6R80 to work well in your Jeep. I absolutely love mine.
Hey Tjers,
I finally have a diesel engine and automatic transmission that works in my TJ Wrangler. After all the different combinations I've experimented with over the years, 3 engines, 6 transmissions, 5 adapters, 2 transfer cases, 7 turbos, and a slew of other parts and pieces, I FINALLY have a combination that is working. I can not tell you how great it felt to take my TJ out onto the road and to be able to do highway speeds for the first time ever without having to worry about heat and to have my TJ just drive like a TJ again.
First I had to wrap up getting the wiring installed for the TDI ECU and the CompuShift ECU. While doing that I realized I had rushed installing my Autometer Gauges so I spent time redoing that work as well on my TJ Wrangler. If there is anything I have learned over the past 5 years is that I need to do things the correct way, not the quick way.
I need to give a huge thanks to HGM Electronics who make the CompuShift transmission controller I'm using. This build would have not been possible without their help and support. For reference to anyone who doesn't know. I'm running an AW4 transmission but I'm using the valvebody out of a 2007 Toyota Tacoma A340F in place of the AW4 valvebody. This was suggested by the people at CompuShift so I wouldn't have to figure out a way to connect the TV, Throttle Valve, Cable to control line pressure in the transmission. There are several other benefits to this approach as well, but the removal of the TV cable and allowing the CompuShift to control the line pressure is the main benefit. I ran into a few technical questions with this setup and the people at HGM Electronics were extremely responsive in getting this combination working with my TDI swap.
Onto the test drive. WOW just WOW. First I will say I ran into a few minor issues which is expected on something like this and they were all a result of things I had done. I forgot to cap off/cover one of the CompuShift wires so that it was grounding on my transmission causing the CompuShift to put my AW4 into 4th gear. I then didn't tighten a boost clamp all the way so it blew off and finally, I had to clear out the gunk in my cooling system. The gunk in the cooling system was a two-fold problem, one being I left the heater core exposed to the elements for years and secondly, I hadn't hooked up the coolant loop correctly the first time, so I ended up flushing the system twice before going on my second road test.
The road tests, I'm not sure what I can say other than it was WAY too cold to be driving my TJ with no top or doors in low 50° weather in November. Nothing overheated and both the engine and transmission acted exactly as I thought they should which was an amazing feeling. The BEW TDI engine with an engine tune from TekMekTronics for the GTD1752vrk turbo worked flawlessly and the CompuShift tune for the AW4 also worked flawlessly out of the box. As of this video, I have not touched the transmission at all. I would say the CompuShift is 90% perfect and would easily allow me to drive my TJ Wrangler wherever I want to.
I can say with 100% confidence that my TJ has not run and driven this well since it had the 4.0l engine and 42rle transmission in it from 2018. After my second road test, I started taking my TJ out for quick errands around town, that's how much confidence I have in my engine and transmission combination.
Now for what needs to be done next. Turns out there is quite a list. I have two major transmission leaks I'll need to investigate, though I know what one of them is already. I need to get my HVAC controls and heat working ASAP if I'm going to be driving this TJ at all this winter, also I need to re-install the hardtop and doors which I will be doing next. Lastly, it's all the minor things I haven't bothered to fix. It needs ball joints, tie rod ends, and I still need to figure out the brakes and steering because my power steering pump is still whinning once everything gets hot. But with all that said, it runs and drives and I couldn't be happier.
Here is the video if you'd like to watch:
Thank you for all the years of help and support with all the iterations of this build!
Grant
I've been offered a chance to go back to the 6r80 with a different adapter AND a different controller. The challenge for me there is I can't run my Rubicon transfer case with the 6r80 because I can't get the correct input shaft for the transfer case. I'll be honestly, it's so tempting to switch back, the 6-speed is awesome, and I think it would really work well too . . . it's something I'm still really considering at this point, I just don't know what transfer case I would pair with the transmission . . .
-Grant
WOW I know that had to be a great feeling to finally get it out driving again. I know it's been a long haul for you but you are at the end now.
Could you get the crawlbox with the correct spline for the 6r80 & then the 241? Do you have the room for it? Plus then you'd have the 2.72 & 4.1 gearing...
It was a fantastic feeling! I can't put into words how good it felt, though all the other things I still have to fix are now obvious as well. I REALLY need to do ball joints and tie rods for my steering.
As for my 6r80, I'm debating going back to it and trying it again with what I have because then I don't need new driveshafts or anything else. Going with a NP231 would be the easiest setup, and I would just need to fabricate a new crossmember, at that point I could swap between the AW4/NVG241OR and 6r80/NP231 setup with changing much else.
It's really tempting to try it out to see if I can get it working this time around.
Thanks
Grant
In a whispering voice: Atlassss.
The first step to dealing with addiction is admitting you have a problem. You're obviously one of those perpetual project guys like most us enablers!
Tire size?I'm almost positive I need gear my axles regardless if I go back to the 6r80 or stay with my AW4, the questions is which gear ratios do I go with?
-Grant
Tire size?
What do the torque and hp curves look like compared to the 4.0l? More or less torque?
My gut wants to say don't gear as deep as for gas.but isn't the tdi a high revver?
Grant,
Great to see you again and that you figured out your cooling system issue.
Hope you're enjoying the TDI swap.
Rick
Hey Rick,
Thank you! I have been truthfully. I haven't done any wheeling with the TJ but for local runs around town it's been fantastic, even without AC figured out yet!
Thanks
Grant
Hey TJers,
For the past several weeks I've been driving my TJ to test the fuel economy of my swap. I did two tests. The first test was a short highway speed test and the second test took the better part of a month driving only in town until I had gone through ¾ of a tank of diesel in my TJ Wrangler.
The highway test I took place on a road where the speed limit was 55mph. Also for this test, I put my CompuShift controller in configuration B which I have set up for manual mode shifting on my shifter, and my torque converter was locked after the transmission shifted in 2nd gear and was above 28mph. For this stint, I drove 66.1 miles and I put back into my tank 1.979 gallons of diesel fuel. The comes out to 33.4 mpg.
View attachment 542612 View attachment 542613
The in-town driving test took the better part of a month. I used my TJ Wrangler exclusive for running errands around town, picking up groceries, going to appointments, etc. On this tank, I left my CompuShift controller on Configuration A, where it shifted my AW4 automatically and the torque converter locked didn't engage until 3rd gear at 51mph. I drove 318.5 miles and put back into my tank 13.04 gallons of diesel fuel. This comes out to around 24.4 mpg.
View attachment 542614 View attachment 542615
Overall I'm thrilled with the results! I think my highway mpg when I'm not shifting the AW4 myself and not being very careful about how much I use the skinny pedal is closer to 31 ~ 32 mpg, which I have gotten a few times since making this video, but my in-town mpg seems very accurate. That being said, there are things I will be working on adjusting and tuning to see if I can improve these results.
Let me know what you think!
Thanks
Grant
did you just skip using any of the Jeep sensor wiring for your gauges? Like what you did with your gauge cluster. Did you hit on your build of that in one of your videos?
I used the sensors that came with the gauges. The only sensor I reused was the CRD Lift Pump fuel level sensor.
I’ve documented it both in videos and this thread but I’d have to go looking for it, I believe it was in 2022.
