P
PNW_LJ
Guest
New Process 241 Rock Trac T/C is 15-1/4"New Process 231 is 20.5"
So a 231 is 5” longer than a 241?
231 has a slip yoke is why the extra length. I'm guessing a 231 with a slip yoke eliminater will be shorter than a 241.
Good machine shops seem to be going away. It really is a shame too but I guess there just isn't the demand for them anymore. Since everything is pretty much throw away.
There used to be a good one over by Covington but it's gone now.
I sent you a private message
Removed the cowl cover and wired in the lights.
Put the cover back on and routed the wires under the hood.
Finished off the end of the loom with heat shrink.
Now to hook everything up.
Have you considered a cabin air filter? Or is that exactly what I’m seeing in that pic?
I’ve had this one saved in my cart for some time now:
https://www.ebay.com/itm/1159898397...pid=5337789113&customid=&toolid=10001&mkevt=1
This is thelights I've got. 4 per side. Figured one in each wheelwell and two in the belly area.
They are made by www.opt-7.com
some many wires running too and fro!
I'm using these RLs: https://luxlightingsystems.com/collections/rock-lights
I've got boring plan ol' White lights as I wasn't interested in the RGB deal since I just wanted them to lite up under the Jeep and wasn't going to try to have a disco with my Jeep.
