Since I got the jeep, cruise control hasn’t worked. The light turns on, but nothing happens after that. A/C and stuff all works fine, does that rule out Vaccum lines? What do I need to check out to get this fixed?
I had the same issue. First thing to do is pull the switches from the steering wheel and clean them up-alcohol and soft cotton. The contacts get quite nasty over 25 years. Before jacking with the steering wheel, disconnect the battery (forgive me for stating the obvious). After they are cleaned, give it a shot. If you are still having the problem, the next culprit is likely the clock spring. If you need to replace the clock spring, I advise you to use the OEM unit. And, as our Disturbed American above states, check all of your vacuum lines.
I'm gonna take another stab at my cruise control issues... I've done some stuff, here's what I know:
- I don't believe there are any vacuum leaks, all lines are in good condition and connected. No cracks found
- I don't believe it is a clock spring problem because everything else is working perfectly, only issues with CC
- The cruise light comes on on the dash but I cannot set cruise speed
- I just cleaned the switches and after doing so did resistance testing on them. Everything lived up to FSM requirements. I probably should've checked resistance before cleaning them too...
- After doing that, I went for a quick drive and tried to set cruise at about 50mph (didn't work) - didn't get the chance to go on the highway to go faster. What's the minimum cruise speed??
Is there anything else to check? Do I need to be driving faster? At this point I feel like the actual module is the issue...
I use mine for quick naps on the drive to work and back. Mostly, I use it for jaunts down to Bean Station TN and to the Outer Banks.
Only way I’m getting a known good one is buying one… don’t know anyone with a tj unfortunately. I’m open to buying one, don’t know where from though, any suggestions? I’m assuming mopar if possible…
My question stands. CC with a manual? I guess some things make sense to certain people. People think my choices are strange.
Took my dog for a swim.
Gave my cat a shower.
I just checked-these are discontinued. There are a number of used servo units for sale on fleabay. Here is the search info-first number is Mopar specific and second number is Jeep specific. Definitely double check for your year and model as there may be something different.
Jeep 4669979 52110387AA SERVO-Speed Control
