Neumeyer
The oil feed line I used a 1/8" Tee and came off the sending unit and drained it back in to the oil pan. The AEM FIC controller I had to figure that out myself AEM has no tune for the Jeep. What is nice is that the Jeep acts totally stock when you have no boost. It runs on the original ecm controller programming. The Aem has an internal MAP sensor that when in boost it see the amount of boost and controls it to your rpm and psi pressure to your setup.
