I’m chasing down death wobble on my 06 LJ. About a year before it started I already replaced my ball joints and hubs. I also just installed Currie currectlync last month and torqued everything to exact spec. I had the wheels/tires rebalanced, and when they did a shitty job, I installed balance beads. I’ve done the dry steering test about a dozen times, but my I untrained eye can’t see anything unusual. The lower control arms aren’t stock from PO, I’m guessing metal cloak because they look gold underneath the crappy black spray job and the upper control arms are stock. None of their bushings look obviously bad or have a lot of movement without a decent amount of pressure. I’m suspect of the trackbar so I included some photos. It’s torqued to spec, but lemme me know if anything looks out of whack. Thanks.
