Where can I find the other end of this horn connector?
joniki
NE Indiana
Any one know where I can find the mate for the horn connector? This is the one that plugs into my 06 horn.
I'm a little confused, are you adding a second horn? The usual place for that connector to plug into is on the horn itself.
Yes. I hate modifying OEM wiring. I am looking to unplug the OEM connector and plugging into another connecter wired to a relay for an air horn.
You'll have to find a matching connector for your air horn which won't be easy since the Mopar parts guide only gives the connector p/n on the end of the cable, not the one on the horn. There's nothing wrong with correctly modifying the OEM wiring if you are up on your wiring and connection/connector skills.
I've had success with connectors at Ballenger Motorsport (https://www.bmotorsports.com/).
Replacing/Rewiring connector: https://wranglertjforum.com/threads/replacing-wiring-connector.58013/
Adding a horn via existing connection: https://wranglertjforum.com/threads/now-it-sounds-like-my-jeep.53286/#post-928871
I looked up my orders and I believe this is the connector I used to connect to the original wire harness horn connection:
https://www.bmotorsports.com/shop/product_info.php/products_id/4341
  • USA Proud
Reactions: Jerry Bransford
