Some of ya'll know what these are, some should know, some will regret knowing and the rest will just be bored.
We're doing a batch of heat treated 4340 tie rods since they are just too good not to be out there.
These are the tie rods with very high resistant to being bent that work with the Currie/Rockjock 4x4 Currectlynk and are threaded to use those tie rod ends. After heat treat they get split and use OEM style pinch clamps the same way the Currie RJ tie rod does.
