I don’t blame you unless I’m at the brewery drinking it.I personally can’t stand the stuff. And I don’t like that wham bam weird crap that’s everywhere so I drink white man Mexican in Premier
The reason the cable breaks is the cable release loop is NOT the pull handle to flip the seat forward. When you pull on that loop to flip the seat forward, it binds the folding mechanism release and stresses the cable. The correct way to do it is with two hands. One on top of the seat to push it back slightly to free up the release mechanism and then pull the loop. While holding the loop under tension, use the other hand to tip the seat forward a couple of inches and then release the loop.Saw this earlier after realizing I couldn’t get one. Hence: f that cable lol. But thanks
Yes they are still around and no it doesn’t require moving the A/C compressor. It didn’t on my 2005 at least.Is magnum powers still around? And if so does it require moving ac compressor. Thanks
I can’t seem to load their website. Is there a vendor I need to go through?Yes they are still around and no it doesn’t require moving the A/C compressor. It didn’t on my 2005 at least.
No, you can only go through their website. The last time I checked it was about a month ago. Hopefully nothing has happened since then. I know Charles is an older guy so I hope he’s still alive.I can’t seem to load their website. Is there a vendor I need to go through?
I just tried and the site loaded for me. Just took a while.I can’t seem to load their website. Is there a vendor I need to go through?
I’ve read and read your posts about them for the past few years. I value your opinion and following your advice as boosted tech is next option. Have a 5.7 LS out of a burb but I’m tired of this Jeep and just want easiest least amount of stress optionNo, you can only go through their website. The last time I checked it was about a month ago. Hopefully nothing has happened since then. I know Charles is an older guy so I hope he’s still alive.
Leave it stock.just want easiest least amount of stress option
I have the boosted tech setup. Leave it stock or V8 swap it.I’ve read and read your posts about them for the past few years. I value your opinion and following your advice as boosted tech is next option. Have a 5.7 LS out of a burb but I’m tired of this Jeep and just want easiest least amount of stress option
I would highly advise against Boosted Tech after my experience with them. If you can find a Banks turbo kit, that would be the far better optionI’ve read and read your posts about them for the past few years. I value your opinion and following your advice as boosted tech is next option. Have a 5.7 LS out of a burb but I’m tired of this Jeep and just want easiest least amount of stress option
I haven’t ever been able to get magnumpowers.com to load. Ever. Not in the past or today
Apparently not a shitty as mineLoaded right up for me 1 minute ago and I have shitting internet.
Won’t load for me
Loaded in 1 second for me. Try another Browser. Chrome, Firefox, explorer...Won’t load for me
Clear your cache/internet history and try again.Won’t load for me
