I use a turkey baster to suck as much as possible out of the reservoir. Refill it and let it run a while, then suck out as much again and refill it. Several of those gets it pretty clean.On a side note. what's the best way to replace the fluid?
That's what I thought. I think I remember seeing Stu remove a line and flush that way but with systems like that as I understand them you run the risk of permanent damage if you run them low or dry.I use a turkey baster to suck as much as possible out of the reservoir. Refill it and let it run a while, then suck out as much again and refill it. Several of those gets it pretty clean.
Jeep engineering did a study on the use of ATF vs. power steering fluid once the switch to ATF was made for the 2003 model. It found them to be compatible with each other in the PS system, but that the ATF slightly outperformed the PS fluid.Does anyone know the actual differences of properties in PS fluid and ATF? Searches, for me at least, dont yield good results.
That type of information should be on the MSDS data sheets for ATF and power steering fluid.Tracking. But what is the actual difference in properties?
Why would you want to replace? they changed to ATF so it was for life.On a side note. what's the best way to replace the fluid?
Like anything it wears.Why would you want to replace? they changed to ATF so it was for life.
Although your 2005 should have had the power steering system filled with ATF+4 at the factory, there may be no way to tell what is in it now. Your only clue will be the color. ATF will look red or pink on a white paper towel. Power steering fluid won't.
ATF is a common substitute for power steering fluid and is specified by many vehicle manufacturers rather than power steering fluid. Both are hydraulic fluids, but ATF has additives and friction modifiers specifically for automatic transmissions. I can find no reliable literature suggesting that those additives and friction modifiers are harmful in any way to a power steering system. All of the literature suggests that power steering fluid and ATF is compatible and interchangeable.
If I were in your position I would use a turkey baster or something similar to suck as much fluid out of the power steering reservoir as possible and refill with ATF+4. However, I have an automatic transmission and can use the leftover ATF+4 for that. If you have a manual transmission and don't need ATF+4 for any other purpose you can use power steering fluid if you only need a few ounces and power steering fluid comes in a smaller bottle and/or is cheaper in your locale.
transfercase
You are responding to a year old post?
My point was simply that if one has a power steering pump that needs a few ounces of lubricant and one doesn't have any other immediate need for a quart bottle of ATF, a smaller bottle of power steering fluid is an option that will cause no harm even if the owners manual specifies ATF.
