No, I used "AUXITO H4 9003 HB2 LED" from Amazon.Did you go with the Beamtechs?
If you use these, note that the alignment ring comes off, allowing you to easily insert them though the rubber gasket (which will still need to be trimmed a bit). Just be sure to put the ring back on the same way it came off - otherwise your bulb will be upside down and the cut-off will be, too. I'm not sure if all the H4 LEDs have this or not.
