Hey guys,
I need a little technical help with my CB install. For reference, the unit is a Uniden 510XL, the antenna is a 4’ Firestik, with spring and AUX connector adapter, and is mounted on my front bumper. I scraped off the paint on the bottom of my bumper to make a ground connection for the bottom of the antenna. I did not grind it with a grinder, but I did file it down. Checked the continuity with a meter, and it seemed good. Per the diagrams, the connector half below the bumper has continuity but the half above the bumper does not. The AUX cable is run through the firewall via an existing penetration (not sure what is currently running through) and inside the Jeep to the CB. The excess cable is folded (not coiled) to one of the supports under the hood. The CB power is wired directly to the battery. I also bought a SWR meter and tuned the antenna to 1:4 at Channel 1 and 40.
So my issue seems to be when I am driving (or at least seems to significantly worse when driving). I can’t seem to pick up anything but static when I am driving. The 4 led lights on the CB unit seem to be maxed out at all times (all 4 are constantly lit) and all I get is static. I can turn the squelch all the way clockwise, and the static is there for about 75% of the turn. All four led lights are continuously on no matter what I do. I can’t seem to pick up anything other than the static. (Ironically I drove my other vehicle with a CB and untuned antenna and get a decent amount of chatter.
Any thoughts?
Any thoughts?
