Been offline for a bit but the TJ has recently got a new idler pully. Stereo upgrade- Speakers and amp, like the looks of the stock head unit so that stays.
Not the TJ, but daughter's Cherokee got new brakes because I heard a nasty grinding noise. Absolutely coming from the right rear. Surprised when I took the drums off and the shoes weren't on the metal. Checked the bearings-good. Checked the diff-good. Checked the pads-good, front bearings and diff-good. Scratching my head because the grinding noise was definitely right rear brake drum noise. Oh well, I'm here, and already dirty, might as well do a full on brake job.
Cleaned everything and replaced them anyway, adjusted them snug and did what everyone does when they change out brakes- Couple of all out lock-ups and anti-lock actuation just to make sure...Glad I did! The rear main line let go and sent the pedal to the floor. So I redid all her brake lines hard and soft.
Daughter is a pretty new driver and I don't think she would have handled the blow out well. I just eased it back into the garage and did all the lines.
Grinding noise magically disappeared??? Not sure if it was divine intervention, good karma or just plain dumb luck, but I'm convinced someone was looking out for her and needed that line to blow while I was driving it.
As a side note-
This is the easiest, most consistent flaring tool I've ever used-
https://www.titan-us.com/default.aspx?page=item+detail&itemcode=51535&catlist=100
