Texas Dana 30 axle
Need a stock Dana 30 axle shaft. Passenger side.
Farmersville texas
I may have one Keith. Let me go look. I broke the driver's side, so the passenger should be around here somewhere.
Reactions: KCsTJ
Well geez, now I can't find it. Heck, I may have even given it away already. I have sooo many parts up there, everytime I go look it's a good refresher. I'll keep an eye out, but I spent 20 minutes up in the attic where it's boiling hot and saw every part I know I have, but I will keep looking.
Reactions: KCsTJ
Hey thanks Jeremy man thats sacrifice there getting in that attic. I bent the ear removing the front axle u joint with my 20 ton press before i found out i did it wrong. No problem somebody around here should have one.
Hope u are all doing well ... I like the progress on your tj .
I learn lots from your posts.
Well, don't give up on me. I can't imagine what I did with that passenger side. I wonder if you could bend the ear back? Of coures, it would have to be pretty darn perfect, so it may not be worth the try. 20 ton press can apply a lot of pressure.
