What should I do to fix my loose Currie steering?
Nick21
Savvy Bumper Club
Washington
By hand I am able to rock my drag link back and forth (front to back) with the pivot happening on the passenger Kunkle end.
What should I do to fix this?
See attached video
Here's a look at the insides. There is a ball joint in there.
Gotcha, makes since. Is the ball joint looser than it should be. I don't remember it being that loose when I have looked at it before.
Have someone help with a steer test and feel if the joints are tight.
looks like it might needs some grease is that sealed or can you add lube? Also if your worried look up the torque spec make sure its torque down properly.
I say that cause i see a gap between your rubber and your knuckle.
