If I want to run 35's, what setup would you recommend for a 1998 4.0, 5 speed Sport with an AX15/5 Speed manual transmission?
Rubi Dana 44 Front/Rear axles, Revolution chromolly axle shaftsIf I want to run 35's, what setup would you recommend for a 1998 4.0, 5 speed Sport with an AX15/5 Speed manual transmission?
Seems like you might be overdoing something this evening.Maybe I'm over doing it?
Vanco/Black Magic Brakes big brake kit if you can swing it. Black Magic Brakes pads and new rotors if you can't swing the BBK.Brakes?
yesI have Dana 44's front and back
from a 2006 Rubicon. Disc brakes front and back. 4.10 gear ratio with 33 inch KO2s
Sorry to hear of your wife’s passing, it seems you are most of the way there already. Better brakes and a gear ratio change would be my focus.Yep. Since my wife passed I'm a little out of it. Thanks for the feedback though
I have a 4" Suspension Lift and I" body liftSorry to hear of your wife’s passing, it seems you are most of the way there already. Better brakes and a gear ratio change would be my focus.
Edit: Providing you have enough lift for proper tire clearance.
I didn’t see that in your profile and I similarly have 4 wheel discs with no braking issues so it seems a gear change to 4.88 or 5.13 would be my next move.I have a 4" Suspension Lift and I" body lift
