After recently installing a 3" lift and new Crown extended brake lines. The front tires contact the brake lines on flat ground at full lock, I imagine that when compressed and at lock it will be worse (the previous TJ I had with a 3.5" lift and extended stainless brake lines did the same thing).
I am thinking about putting a small hose clamp on the lines somewhere near the middle and connecting a small bungee cord from the hose clamp to the inside part of the frame rail to pull it out of the way a bit.
Thoughts on this, or other solutions?
