2000 TJ 4.0. Just took the battery out, cleaned up both terminals with a Dremel along with the battery posts themselves. Installed battery back into Jeep, turned the ignition and NOTHING. Horn does not blow, lights wont turn on. What the heck did I do wrong? Double checked to make sure I had the negative to negative and positive to positive that's all set. Soooo any ideas? Jeep was running fine before, no issues whatsoever. Readings on the battery gauge prior to this was right at 14 all the time.
