Finished installation of the Noico sound deadening material and got the front Bedrug put in this weekend. My supervisor wanted to be in the photo....
I saw some reviews that people said the black would flake off, did you run into that issue?
Took the boy and .22 out for some plinking.
I saw those as well. I've had the black Noico installed in the cargo area behind the rear seat for nearly a month now (I did that area first) and haven't seen any flaking. Also - during the install process I didn't wear gloves and never had any black wear off onto my hands...so far so good!
Reactions: JpZombie
Mounted my new tires in my driveway. Bead locks are easy, but tedious. Lots of bolts to torque and re-torque, and re-torque.
Took about 20 mins a wheel start to finish. Put 8.5oz of balance beads in each tire. These are a good inch taller than the Treps too. Weird, because the specs have the Treps taller, but I compared both inflated and demounted OD.
View attachment 252484View attachment 252485
20 minutes per tire to mount is impressive. Nicely done!
I only got the frame drain hole drilled on the other side - business came up so I couldn't do the other rear UCA. Have a dance session tomorrow, so that'll have to wait until Thursday.
Reactions: Vasq
Zorba - You might weigh your priorities. You won't dance forever but your Jeep will last forever.
I've spent my entire dance career learning from "old crones" that had "been there, done that". Now, suddenly, *I'M* the "old crone" and am passing the lore down to the next generation.
I need to write a book, "Dressing Rooms I Have Known..."
