Thanks for noticingAnother funny thing, this thread is titled "the look" of the headlights![]()
I'm doing the same. Used Rustoleum truck liner on the bezels which look awesome and hold up really well.I don’t like how LEDs look so I’m also running stock, but with black bezels. Once I properly aimed the headlights I stopped thinking about upgrading.
So my build is a bit funky, trying to blend old and new, tastefully. Flat fenders front, flare delete rear.
My bezels are painted metallic charcoal, and match my wheels.
Long and hard thought, went w/ a blue tinted headlight...I like it, and it's different.
I thought there were more accidents at night per mile driven today than there were 10 years ago with much lower power headlights?
If I decide to go stock, and to keep the hella housing, do you think It would be better to use a halogen bulb with higher wattage, or stick to a good choice 55/60W halogen bulb like the Philips Xtreme Vision +130 you suggested?FYI - the factory incandescent headlamps are 60/55w halogen bulbs, just inside a sealed housing.
It is the lens quality/light pattern of the Hella and Cibie E-code housings that makes the light shine farther with the same wattage bulb. Philips Xtreme Vision +130 and similar bulbs by other manufacturers are slightly "whiter" in color temperature than the usual 60/55w H4 (but still not blueish) which makes them appear even brighter to the driver than the standard H4 even though the wattage is the same.
Personally, I don't care for the look of LED headlamps on a TJ/LJ and the light is too blue for my tastes, i.e. too harsh. That includes the "cheap" Chinese Trucklite knockoffs that seem to be so popular on the Internet jeep forums. Ironically, the cost of a set of Hella E-Codes and +130 H4 halogen bulbs is less than the Trucklite knockoffs and in my humble opinion work better.
If you go with higher wattage, you would want to upgrade the headlight wiring to accommodate. I suggest the 55/60w halogen.Nice thread! I am in the market to upgrade my headlights atm. PO installed some Hella Housings with some very cheap halogen bulbs. (Osram H4 Original Line - 60/55W)
Also, installing a led bulb inside the hella housing would be appropriate? or not?
Thanks!If you go with higher wattage, you would want to upgrade the headlight wiring to accommodate. I suggest the 55/60w halogen.
I tried a few different LED bulbs in the stock housing, and the light pattern for each was just terrible, so I switched back.
The Philips are a great choice, xtreme vision or not. They last a long time and have a great pattern and those are what I used.Thanks!
So I'm sticking to a good 55/60W halogen bulb inside my Hella Housing for now.
Which bulbs are you running right now? Do you have any suggestions?
Hey! Thanks for the answer!The Philips are a great choice, xtreme vision or not. They last a long time and have a great pattern.
I am currently running Truck Lites leds with the heated lens to see how well I like them. That was the other issue with the led bulbs-not enough heat generation to keep the lenses clear of ice and snow, though you don't have that issue in Athens GR (generally speaking). Skiing at Parnassos may be a different story.
So far, the Truck Lites work very well, don't blind the other drivers, and definitely have a much longer reach on high beams than the stock halogens.
A refresher on headlight adjustment.
No doubt that LED headlights are brighter than stock.
HOWEVER... who has retained the stock headlights for the more classic look and feel?
