Hey Members want to get some suggestions for my RHD TJ, its time for new steering links upgrade, and seems I can't find good quality options like regular TJ can have, any intel would be a big help thanks in advance.
The currie currectlync is well liked here and a very strong upgrade. I cant seem to find it for your RHD. Give Currie enterprises a call and see what they have.Hey Members
i did I just got my front wiper motor but no luck on steering partsHave a look on some of the australian Jeep forums (not sure if im allowed to mention which one), I'm sure there'll be plenty on there for RHD steering.
I hope so, just took me over a year to get the wiper motor for it.Your options are limited, that's for sure. I'm not sure what they are, but maybe someone will chime in.
generic parts are not too hard to get I was looking to upgrade to Steinjager Crossover Steering Kit or something like that styleYou should be able to use a generic tie rod
https://www.amazon.com/dp/B00B2AG380/?tag=wranglerorg-20
The forged drag link is goimg to be the hard part to upgrade.
I’d never looked at that until now. It’s just generic parts in a kit.generic parts are not too hard to get I was looking to upgrade to Steinjager Crossover Steering Kit or something like that style
| Drag Link + Tie Rod |
| Tie Rod |
| Tie Rod End |
| Adjusting Sleeve for both |
| Steering Damper - average non branded one. Not sexy like fox or anything. |
cheersI’m in the process of replacing mine (bit wobbly and needs tightening up).
If you want just like for like, I got a RHD drag link and Track Bar from quadratec delivered here in NZ.
it’s the Crown brand (not sure how good they are but not much else out there)
For tie rods you can use lhd ones as they fit too. Same with the steering stabilizer
hey let me know how you like your setup after you got it installI’m in the process of replacing mine (bit wobbly and needs tightening up).
Cheers
i will check them out thanksIronrock offroad do RHD kits. Not sure how good they are though.
it looks like Steinjager Crossover Steering Kit , will call them tomorrowHere is another option for a RHD steering upgrade I found...
https://kevinsoffroad.com/collectio...-the-knuckle-steering-kit?variant=43510006538
Apparently the Synergy kit can be flipped for RHD use, as the ball joints at both ends of the drag link can be swung around.
https://www.synergymfg.com/synergy-jeep-tjlj-xj-zj-mj-heavy-duty-steering-kit.html
As already suggested, the LHD tie rod will fit RHD TJ's. Crown also do a Heavy Duty RHD drag link and tie rod.
