egclassic
If it wasn't applied thick enough, it won't peel off that easily. When the PO did the grill, it was a very thin coat and when I tried peeling it, just tiny pieces would come off. Finally tried the wd-40 trick and it removed it much easier.Plasti dip should peel off fairly easily unless he hit it with sandpaper first [emoji849]
I couldn't imagine having to remove black spray paint from an entire jeep!
