M8000s $893What did you get?
Ooooh, almost got one of them, curious to see how they turn out2002 - 2006 Subaru Baja, and there is rumors of a 2021 model in the works...
Done hijacking
Already bought some, Alien were going to replace but I told them its not worth the trouble, I only mentioned it to them so they keep up on Quality Control. We have Bunnings in OZ but nowhere near as many products and choice as Lowes.Liking the blue trend there. Those bungee balls are getting popular. Here in the U.S. we have them at lowes next to the tie down and bungee cord section, not by the tarps funny enough. You might be able to find them at your local DIY store. Do they have DIY stores on that side? LOL
I have been looking for this set up, where did you bought it?First step for my version of underhood heat reduction.
I didn't buy it, I made it. I laid out a stock fender with flare, made a very clean cardboard template, had that laser cut, laid out holes around the perimeter evenly spaced between corners, drilled those, pressed in PEM studs, then I welded #4 .062 SS wire mesh to the inside.I have been looking for this set up, where did you bought it?
So its just small pivoting soft top cages that fit on top of the doors? coolStill 70 in Atlanta so installed the “flip ur top” kit. Should have done this earlier. Stock soft stop to sunrider in an hour and for $60
A thing of beauty, congrats!
Has this ever had a re paint or is it original? man that is a piece of artA balmy 57 degrees here in NJ, so I decided to give her a bath.
Back when I had my '97 I picked this one up at a swap meet because I had turtled mine a few too many times and I just never got around to replacing it before the Jeep went away. I actually have another one that came with the 2000 I have now bit it's not the same, I'm thinking it might be for the newer models. Plus it's been turtled too. The one I put on the Jeep hasn't been bent at all.How did you get two of them? Just for a spare?
That’s original stone white. Thanks! If you zoom in you’ll see some imperfectionsHas this ever had a re paint or is it original? man that is a piece of art![]()
