Hey Chris, good friend just asked if I knew anyone looking for either a drone or a Go Pro setup. His stuff is always nice, we camp with them quite often. Do you want me to connect you guys?
Do you know what kind of GoPro and Drone it is by chance?
I'll ask on the Go Pro, I know the drone is a Mavic Air and he's got a lot of accessories.Do you know what kind of GoPro and Drone it is by chance?
It's a Go Pro 8 and 3 batteries and charger.Do you know what kind of GoPro and Drone it is by chance?
It is a Hero 8 and the drone is not the Pro 2.I was looking at buying a GoPro HERO8 so depending on what he wants, I would definitely take it off his hands.
As for the Drone, is it a Mavic Pro 2? That’s the one I want for the 4K video. I had the original Mavic and really liked it.
What did he quote you on that? Jason seems like a really good guy from the interaction I’ve had with himRear bumper incoming... Also ordered the Dave Kishpaugh's rear geometry correction brackets. I'm not set up for much fabrication, so I will be working with Jason at Absolute Offroad in Phoenix to set up the rear axle. I'll post up photo's along the way.
4 hours, so $400ish... I told him I thought that was optimistic, and he said I'd be surprised how quick he could have us welding those on... I think lining up the pads is where I would bank more time, but we'll see. I'll let you know, we're going to do it in a few weeks.What did he quote you on that? Jason seems like a really good guy from the interaction I’ve had with him
As long as the track bar ends up in a good place, it should just be an adjustment on the control arms and done.That sounds super reasonable to me. Dave said it’s a pretty easy straightforward job
Also got the ACOS in the front. These aren't really common, but I didn't like the way my springs were seated on the spacer I had and I was a little low in front and knew it was going to be more when I added the bumper and winch. They are adjustable height so I can make changes if I want to. And I was already up in the rear from my correction wedges which I chose instead of an upper spring perch relocation. Went this way because I was going a little higher lift to run the 35's on a kit designed more for 33's. Was it "needed"? Not necessarily, but I like a certain amount of fender clearance and this was the way I chose to get it. What it did do was put my shocks out of whack a little... I'm at 6.5 up and 3.5 down in the front. That will clean up with the RS5000X RS55255 which will put me at 5+ and 5+, optimal if I follow the pro's recommendations. Can't wait to get rid of these Zone Nitro shocks... Will also need 1" more bump if everyone's collapsed length measurements are comparable. But the look great in there for sure and the spring seats perfectly now.
Nice! I just haven't seen them in a lot of builds. But they are a nice piece for sure. And I'm looking forward to the adjustability when I get a little more weight on the front.
So, general consensus it they are just too much $$ for what you get. Considering that they start at about 1.75" of spacer, and go up from there... Most people with full lift kits aren't looking for that much spacer. So I get it it, it's a bit of a niche product and they are expensive for what they are. The good part, is nobody had a complaint about what they did. No, I do not plan to adjust them more than the initial setting once I have my base weight determined... And the cost is mostly irrelevant to me.Here are a few but there are more in conversations about other things.
JKS ACOS Pro: Adjustable coil over spacers with adjustable nitrogen bumpstops? | Jeep Wrangler TJ Forum
Anyone running an ACOS on their TJ? | Jeep Wrangler TJ Forum
Can I (and should I) use coil spring spacers? | Jeep Wrangler TJ Forum
