I posted about this a little while back but my o2 sensors keep giving me codes (P0174, P0157, P0031, P0037, P0051, P0057, P0157) These are for bank 1/2 lean and bad heaters. I thought the culprit was that I had replaced them with bosch ones in the spring, but I checked them and it turns out i did use the correct NTK ones after all. I then read that it can be a bad block ground (ground wire 105) so I checked and cleaned it and it seemed ok, but i'm not sure if i did this right as the light came back on. Has anyone else had this bad ground issue causing o2 sensor codes? I'm not sure how extensively to clean it, or what causes this connector to get corroded. Also, what other issues can cause this code? My jeep is an 05 automatic
,and i've heard alot of them have pcm issues. I've also heard to check the harness, but before I do, has anyone actually had a harness go bad? If so, where was the break/bad connection? Any other ideas on what could be causing the issue? If anyone has an answer to any of these questions it would be a huge help!
